Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Examine the damage. Clip any long threads, and remove any debris from the hole.
Measure the damaged area.
In our case it looks to be 2" by 2".
Draw any the shape you'd like your patch to be on a piece of paper. Be sure your design is at least 1/8" larger than the damaged area.
Cut out your design.
Lay the cutout of your design over the hole in the jeans to make sure that it is the correct size and looks how you want it to.
Using a pencil, pen, or tailor's chalk, trace the design onto the jeans.
Take the scrap of fabric you will use for a patch and insert it into the hole.
Slide the pant leg with the patch over the arm of the sewing machine.
Adjust the sewing machine for a zig-zag stitch.
Set the stitch length to just under 1/2.
Align the edge of the patch with the center of the pressor foot.
Be sure that the patch is laying flat.
Lower the pressor foot.
Begin sewing the zig-zag stitch, following the edge of the hole so that the zig-zag stitch covers the area where the two fabrics meet.
Sew all the way around the patch.
Overlap the stitching at the end with the first two or three stitches.
Lift the pressor foot and needle.
Slide the pant leg off of the arm of the sewing machine.
Clip any threads, and admire your work.
5 участников успешно повторили данное руководство.
2 Комментариев
worked! i’ve been wearing these torn pants for years. thanks so much!
