Revlon One-Step Hair Dryer Lint Filter Replacement
Выберете то, что вам нужно
  1. Revlon One-Step Hair Dryer Lint Filter Replacement, Barrel: шаг 1, изображение 1 из 1
    • First, remove the pink panels on each side of the handle in order to access the screws.
    • Use the iFixit opening tool to remove the pink panels.
  2. Revlon One-Step Hair Dryer Lint Filter Replacement: шаг 2, изображение 1 из 3 Revlon One-Step Hair Dryer Lint Filter Replacement: шаг 2, изображение 2 из 3 Revlon One-Step Hair Dryer Lint Filter Replacement: шаг 2, изображение 3 из 3
    • After removing the pink panels, there will be one visible screw on each side of the dryer handle measuring at 11mm.
    • Carefully unscrew both of these screws with a tri-point Y000 screwdriver.
    • Next, completely remove the screws out of the dryer handle.
  3. Revlon One-Step Hair Dryer Lint Filter Replacement: шаг 3, изображение 1 из 3 Revlon One-Step Hair Dryer Lint Filter Replacement: шаг 3, изображение 2 из 3 Revlon One-Step Hair Dryer Lint Filter Replacement: шаг 3, изображение 3 из 3
    • Remove the barrel by twisting and pulling it away from the handle of the dryer.
    • Before attempting to take the barrel off, make sure the dryer powered completely off and is cool to the touch.
  4. Revlon One-Step Hair Dryer Lint Filter Replacement, Cord and Plug: шаг 4, изображение 1 из 2 Revlon One-Step Hair Dryer Lint Filter Replacement, Cord and Plug: шаг 4, изображение 2 из 2
    • Next, slide down the air inlet and the setting dial to reveal the 11mm screws on each side of the handle at the bottom of the hair dryer.
  5. Revlon One-Step Hair Dryer Lint Filter Replacement: шаг 5, изображение 1 из 1
    • There will be one visible screw on each side of the dryer at the bottom of the handle, measuring at 11mm.
    • Store screws in a safe place, you will need them to reassemble the device later.
  6. Revlon One-Step Hair Dryer Lint Filter Replacement: шаг 6, изображение 1 из 1
    • Place the iFixit opening tool along the seams of the handle and pry the two pieces apart.
  7. Revlon One-Step Hair Dryer Lint Filter Replacement: шаг 7, изображение 1 из 3 Revlon One-Step Hair Dryer Lint Filter Replacement: шаг 7, изображение 2 из 3 Revlon One-Step Hair Dryer Lint Filter Replacement: шаг 7, изображение 3 из 3
    • Once you have exposed the inside of the dryer, you will see a clear port at the very end where the cord is connected and plugged into.
    • Now, with your thumb and pointer finger gently pinch the top and bottom of the clear port.
    • Next with your free hand carefully pull the cord out of the port of the dryer handle.
  8. Revlon One-Step Hair Dryer Lint Filter Replacement, Setting Dial: шаг 8, изображение 1 из 1
    • Once the cord is disconnected from the handle, you should be able to slide the dial setting off completely and free it from the cord.
  9. Revlon One-Step Hair Dryer Lint Filter Replacement, Lint Filter: шаг 9, изображение 1 из 1
    • Remove the air inlet by sliding it completely off of the wire.
  10. Revlon One-Step Hair Dryer Lint Filter Replacement: шаг 10, изображение 1 из 3 Revlon One-Step Hair Dryer Lint Filter Replacement: шаг 10, изображение 2 из 3 Revlon One-Step Hair Dryer Lint Filter Replacement: шаг 10, изображение 3 из 3
    • Take the lint filter out from the air inlet by peeling it from the sides.
Заключение
3 участников успешно повторили данное руководство.
Emma Grace Bender
Участник с: 03/21/22
118 Репутация
1 руководство автора
Команда
University of Alabama, Team 1-4, Bedsole Spring 2022 Участник University of Alabama, Team 1-4, Bedsole Spring 2022
UA-BEDSOLE-S22S1G4
3 членов
Автор 5 руководств
Один комментарий
I' just fixed mine following your instructions.. Thanks a lot for the share.
Lint Remover - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 69
За последние 30 дней: 402
За всё время: 13,450
