Введение
The Ricoh Super 8 800z operates using a 8mm film cartridge. Inside this film cartridge is a reel with an 8mm film. The hooks you will be replacing are what latches on to and rotates this reel.
Выберете то, что вам нужно
Open the device's film cartridge door by pulling the release switch towards the eyepiece.
Lay the device with the left side down and the door open to allow access to the film cartridge hooks.
Using a Phillips #000 screwdriver, remove one of the screws from the rotating hooks in the center of the film bay.
Now put your finger on the side of the screw you just removed, and take out the remaining screw with a Phillips #000 screwdriver.
