Введение
This process involves removing the back cover and the front cover of the camera. After, the lens can be removed from the camera body.
Выберете то, что вам нужно
Use the screwdriver to unscrew the indicated screws from the left, right, bottom, and back sides of the camera.
Loosen the back cover from both the left and the right sides of the camera. Take off the back cover.
Open the film compartment.
Press your finger on top of the grey latch on the left side of the camera.
Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
Use your fingers to completely remove the metal pin.
Remove the film compartment door.
Use a thin shaft screwdriver and unscrew the two indicated screws within the film compartment.
Loosen the front cover from the left and right sides of the camera.
Take off the front cover.
Unscrew three screws from the outermost plastic plate covering the lens.
After the screws are removed, the outermost plate can be removed.
Remove the ring shaped metal brace.
Using fingers or tweezers, remove the lens from the camera.
