Введение
Disassembling the handle assembly will be necessary for any rewiring or switch replacement needs. Jammed switches or a damaged power cord will require these preliminary steps for repair.
Выберете то, что вам нужно
Using a Torx T20 screwdriver, unscrew the five M5 x 16 mm screws.
Using the T20 screwdriver, remove the M5 x 28 mm screw.
Press down the handle lock button.
Force-ably twist and pull away the left side handle assembly.
Еще один человек закончил это руководство.
