Введение
If during a work session you accidentally drop the device and fracture the power trigger, you will need to replace it. The inner mechanism can also break resulting in a broken power trigger. This guide will show you how to disassemble the handle and replace the switch.
Выберете то, что вам нужно
Using a Torx T20 screwdriver, unscrew the five M5 x 16 mm screws.
Using the T20 screwdriver, remove the M5 x 28 mm screw.
Press down the handle lock button.
Force-ably twist and pull away the left side handle assembly.
Using a bit driver, carefully remove the 4 M3.5 X 7mm holding the wires on.
The Switch is now free of the Grinder. Dispose of the broken Switch and install your new Switch.
