Введение
This guide shows you how to replace the torsion levers for both the cutting depth and blade angle guides of the saw. These parts made out of plastic and will break if too much force is applied. For more information take a look at our troubleshooting guide.
Выберете то, что вам нужно
Remove the battery by pressing both buttons on either side of battery and pull away from the saw.
The blade angle lever is located on the front left of the saw and connects to the base assembly.
The blade depth lever is located toward the rear of the left side of the saw behind the motor shroud.
Slowly loosen the 7mm Torx T20 screw holding the blade angle guide lever in place. There is a compression spring between this screw and the lever.
After the screw is loose from the last thread, slowly back the screw away from the lever gradually releasing pressure in the spring.
Align the new lever on the mounting post.
Rest spring inside the lever mounting hole and fasten in place with the 7mm Torx T20 mounting screw.
