Введение
The Drive Gear Cover for the Ridgid JobMax R8620 Series E is a crucial part of the device because it allows you to have control. If it is not working properly, please view this guide to see how to replace it.
Выберете то, что вам нужно
Pull the battery out of the case by hand before opening the device.
Using a Torx T10 screwdriver, remove the nine 6mm screws on the drill cover.
Lift off the outer casing.
After opening the cover, find the motor and pry it apart from the case in order to have space to do the replacement.
Find the gear cover.
Using a Phillips #0 screwdriver, remove the two screws on the plastic protective plate.
Remove the plastic plate.
