Введение
Ridgid JobMax R8620 Series E has a built-in LED light that is controlled by a switch trigger. If your LED light is functioning properly but is not turning on, it is likely that there is a problem with this switch.
Выберете то, что вам нужно
Pull the battery out of the case before opening the device.
Remove the nine 6mm screws on the drill cover using a Torx T10 screwdriver.
Lift off the outer casing.
Remove the plastic switch with the spring from the groove of the housing by hand.
Find the slot on the motherboard along the wiring of the device.
Use tweezers to pull the plug out of the host slot.
