Введение
If you are having trouble with the motion-activated lights and you would like to replace them, follow the 4 steps that are provided. It will take approximately 15-35 minutes.
Выберете то, что вам нужно
Use the metal spudger set to break the glue lining and the motion sensor will pop out.
6 участников успешно повторили данное руководство.
2 Комментариев
this showed nothing about replacing the light bulb
This is not a complete how to. The directions stop in the middle and don't show the replacement of the LEDs. Also no parts link for the replacement LED strips
