Введение
In this guide, we will show you how to replace the camera in a Ring Stick Up Cam. You will need a Phillips #00 screwdriver and a plastic opening tool.
Выберете то, что вам нужно
Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
Еще один человек закончил это руководство.
2 Комментариев
Where can I purchase a new lens?
Any ideas where to get a new lens?
