Ripped Soccer Cleat Repair Technique
Выберете то, что вам нужно
  1. Ripped Soccer Cleat Repair Technique, Ripped Soccer Cleat: шаг 1, изображение 1 из 1
    • Using a toothbrush, clean the entire cleat, especially where the shoe is ripped.
    • The toothbrush will help get any excess dirt or turf out from under the ripped area.
  2. Ripped Soccer Cleat Repair Technique: шаг 2, изображение 1 из 1
    • Squeeze out a good amount of the Shoe Goo onto the piece of printer paper.
    • Shoe Goo will help adhere the sole of the cleat to the leather.
    • Be sure to have a clean air source in the room, as this glue has strong fumes.
  3. Ripped Soccer Cleat Repair Technique: шаг 3, изображение 1 из 2 Ripped Soccer Cleat Repair Technique: шаг 3, изображение 2 из 2
    • Using the paint brush, paint the glue in the opening of the ripped cleat and between the leather and the sole of the cleat.
    • The glue is very sticky and dries fast. Make sure to paint it inside the rip as soon as you squeeze the glue out onto the paper.
    • Let dry for 3 minutes and repeat the step again.
  4. Ripped Soccer Cleat Repair Technique: шаг 4, изображение 1 из 2 Ripped Soccer Cleat Repair Technique: шаг 4, изображение 2 из 2
    • Press the cleat together firmly and wrap a few pieces of newspaper around the sole of the shoe.
    • The newspaper helps the glue not get stuck to anything.
  5. Ripped Soccer Cleat Repair Technique: шаг 5, изображение 1 из 2 Ripped Soccer Cleat Repair Technique: шаг 5, изображение 2 из 2
    • Wrap the adhesive tape around the newspaper tightly to keep pressure on the tear until the glue dries.
    • The adhesive tape keeps pressure on the tear while it dries.
  6. Ripped Soccer Cleat Repair Technique: шаг 6, изображение 1 из 1
    • Use a hair dryer to slowly warm the newspaper surrounding the tear. Do this for 10 minutes, then let the shoe rest.
    • Make sure to hold the hair dryer 4-6 inches away so the tape and newspaper don't over heat as glue might bubble.
  7. Ripped Soccer Cleat Repair Technique: шаг 7, изображение 1 из 2 Ripped Soccer Cleat Repair Technique: шаг 7, изображение 2 из 2
    • After 24 hours, remove the tape and newspaper.
    • Then once the tape and newspaper are removed, peel off any excess glue that is stuck around the area of the rip.
Заключение
Once the steps above are completed, your cleats should be repaired and ready for play!
2 участников успешно повторили данное руководство.
Devan Talley
Участник с: 07/03/18
202 Репутация
1 руководство автора
Команда
Eastern Washington University, Team S2-G1, Crane Summer 2018 Участник Eastern Washington University, Team S2-G1, Crane Summer 2018
EWU-CRANE-SU18S2G1
4 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 23
За последние 7 дней: 138
За последние 30 дней: 630
За всё время: 15,071
