Введение
Ripped soccer cleats are a very common issue and many people think once ripped, the cleats are unusable. This FastFix guide will demonstrate exactly how to repair your ripped soccer cleats with step by step instructions using photos to help you. Fix your ripped cleats with assurance without buying or breaking in a new pair.
Выберете то, что вам нужно
Using a toothbrush, clean the entire cleat, especially where the shoe is ripped.
Using the paint brush, paint the glue in the opening of the ripped cleat and between the leather and the sole of the cleat.
Let dry for 3 minutes and repeat the step again.
Press the cleat together firmly and wrap a few pieces of newspaper around the sole of the shoe.
Wrap the adhesive tape around the newspaper tightly to keep pressure on the tear until the glue dries.
Use a hair dryer to slowly warm the newspaper surrounding the tear. Do this for 10 minutes, then let the shoe rest.
After 24 hours, remove the tape and newspaper.
Then once the tape and newspaper are removed, peel off any excess glue that is stuck around the area of the rip.
Once the steps above are completed, your cleats should be repaired and ready for play!
2 участников успешно повторили данное руководство.
