Введение
The Rival single cup coffee maker has a heating element that is prone to breaking. If the device is left on for too long, the heating element can over heat and stop working.
Выберете то, что вам нужно
Remove the base plate by pressing the plastic body away from the metal plate with your thumbs.
Remove the 8mm Phillips screw that attaches the power button to the inside of the coffee maker.
Use a flat head screwdriver to pry the power button from its slot in the body of the device.
Remove the two 8 mm Phillips screws from the chassis of coffee maker.
Pull back the metal backing from the plastic body.
Flip the device upside down and remove the outer plastic body from the device by pulling straight up.
Remove the 4 springs holding the water tubes by squeezing the 2 prongs together.
Bend the heating element back and forth to wiggle the water tubes loose from the plastic.
Еще один человек закончил это руководство.
