Введение
First, make sure that the device is unplugged from the socket. Before replacing the power button you must unscrew the metal base plate. After doing this all you need to do is unscrew the button on the inside of the device and pry it out of the slot on the body of the device. Pry with enough force to detach the button but not so much that it breaks the plastic button.
Выберете то, что вам нужно
Remove the base plate by pressing the plastic body away from the metal plate with your thumbs.
Remove the 8mm Phillips screw that attaches the power button to the inside of the coffee maker.
Use a flat head screwdriver to pry the power button from its slot in the body of the device.
Еще один человек закончил это руководство.
