Введение
The Rival single cup coffee maker has water tubes that a prone to leaking. If boiling water runs through the tubes for too long, they can come loose and leak water. The tubes are held in by a simple spring that can be loosened by hand.
Выберете то, что вам нужно
Remove the base plate by pressing the plastic body away from the metal plate with your thumbs.
Remove the 8mm Phillips screw that attaches the power button to the inside of the coffee maker.
Use a flat head screwdriver to pry the power button from its slot in the body of the device.
Remove the two 8 mm Phillips screws from the chassis of coffee maker.
Pull back the metal backing from the plastic body.
Flip the device upside down and remove the outer plastic body from the device by pulling straight up.
Remove the 4 springs holding the water tubes by squeezing the 2 prongs together.
Bend the heating element back and forth to wiggle the water tubes loose from the plastic.
Remove the two rubber water tubes from the heating element by firmly pulling each at a 90 degree angle from the socket.
