Введение
This guide will help you remove the motor and requires the uses of a soldering iron. Check out this soldering guide for help if you don't know how to solder.
Выберете то, что вам нужно
Twist the plastic lid counterclockwise to unlock it.
Lift the lid to remove it from the container.
With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
Use your fingers to pry out the two rubber feet from the bottom cover of the base.
Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
Continue turning the gear until completely removed from the blade-shaft.
Use the plastic opening tool to pry open the base from the main body.
Once freed, lift the base panel from the main body. The motor and power cable are connected to this panel.
Use a Phillips #2 screwdriver to remove the screws that attach the motor to the base.
Pull the power cord wires up from underneath the wire hook on the side of the motor.
Carefully cut into the black wire casing for both wires using a small knife, and peel away the black casing.
Use a soldering kit to remove solder from the circuit board for the red wire.
Follow this soldering guide if you need extra help!
Use a small knife to cut the copper wires from the bracket holding the black wire and power cord together.
Use a Phillips #1 screwdriver to unscrew the single 4.76-mm screw from the motor base to finish removing the motor.
3 человек успешно провели ремонт по этому руководству.
