Введение
This guide will help you remove the power button.
Выберете то, что вам нужно
Twist the plastic lid counterclockwise to unlock it.
Lift the lid to remove it from the container.
With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
Use your fingers to pry out the two rubber feet from the bottom cover of the base.
Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
Continue turning the gear until completely removed from the blade-shaft.
Using Phillips #2 screwdriver, unscrew two 12.7-mm screws in the middle of the base.
Use the plastic opening tool to pry open the base from the main body.
Once freed, lift the base panel from the main body and set it aside.
Use a Phillips #2 screwdriver to remove the three 9.53-mm screws from inside the main body.
Next, turn the device upright and lift the upper casing from around the button gently.
