Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will help you remove the turning gears of the Rival Mini Blender. Removing the gears will allow you to access the interior components of the device.
Выберете то, что вам нужно
Twist the plastic lid counterclockwise to unlock it.
Lift the lid to remove it from the container.
With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
Use your fingers to pry out the two rubber feet from the bottom cover of the base.
Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
Continue turning the gear until completely removed from the blade-shaft.
Еще один человек закончил это руководство.
