Введение
If your mouse start to register double-click when you click only once, this might be a worn switch.
Выберете то, что вам нужно
All screw are hidden below the mouse
Peel off the mouse pad to uncover 5 of the 6 screws
The last screw is in a hole under the sticker. You don't need to remove the whole sticker to uncover it.
unplug the remaining connectors
carefully pull-down the Ribbon cable to unplug it
remove the last screws and pull the board free
the mouse wheel LED assembly is a separate piece you need to unscrew.
you need to pull the mouse wheel to the right to get it out
I want to change the left switch.
flip the board to unsolder the switch.
Only two legs are soldered, this is the third one
The new switch replace the old one not working.
The button should be on the left
7 участников успешно повторили данное руководство.
Один комментарий
Greetings,
Would you happen to know the part number for the x-celerator paddle potentiometer replacement?
Thanks!
