Введение
Replace the case of the device.
Выберете то, что вам нужно
Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
Note: It may take several heats, left for a minute at a time, to loosen the glue.
Use the 000 phillips to remove the screws found under all four of the rubber pads.
Remove the middle component that is held in place by the top and bottom of the device.
Remove the board from the plastic enclosure and put the board into the replacement enclosure.
Еще один человек закончил это руководство.
