Введение
If your remote control buttons are no longer working effectively, this guide will show you how to replace the buttons on your remote.
Выберете то, что вам нужно
Flip the remote over so that the buttons are facing down and the end with the wrist strap is nearest your right hand.
Press and hold the black tab above the battery compartment.
While holding down the tab with your left hand, slide down the battery compartment cover with your right hand to remove it.
Remove the batteries by placing a finger on one end of the battery and pushing downward while pulling the battery out.
Unscrew one 7 mm Phillips #0 screw from the center of the battery compartment.
Separate the top and bottom of the remote casing.
Gently place each half of the remote onto a table so that the exteriors are face down.
Carefully flip over the front casing side of the remote so that the buttons drop onto the table.
4 человек успешно провели ремонт по этому руководству.
4 Комментарии к руководству
Do you have a source for getting replacement buttons? I have volume buttons that don't work and was hoping to fix them/ replace them. Thank you!
Hi Patrick,
I literally just finished successfully fixing my volume-up button.
The replacement part number for the right microswitches is EVQ-P7J01P, available at Digi-Key:
https://www.digikey.com/product-detail/e...
Really inexpensive (around 30 cents each). Pro-tip - to help remove the old switch easily, cut it in half with sharp side-cutters.
Good luck!
Jeff T.
Where can I find a component layout?
Setuproku provides support for all roku related issue. This article help us to understand the Roku remote control.
