Введение
The motherboard is a piece of circuitry that serves as the device's circuit board. The primary internal parts of the Roku 4 are all attached to the motherboard. This disassembly guide will serve as the core to further internal disassembly, as you will be able to fix other parts from here.
Запчасти
Детали не указаны.
Place the Roku 4 face-down on a table. The rubber sticker should be facing you.
Starting at one corner of the device, pull the rubber sticker back toward the opposite corner of the device carefully to reveal the underlying screws.
Completely remove the rubber sticker to reveal the underlying screws on the device.
Turn the Phillips PH1 screwdriver counterclockwise to unscrew all 4 of the 12.0 mm screws.
Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device and create a gap.
After you have created a gap large enough to fit your fingers between, gently lift up the top cover to open the device and reveal the motherboard.
To begin removing the motherboard from the plastic casing, pinch the black plastic clip and gently pull upward.
Once you feel the motherboard begin to loosen from the plastic casing, pull it upward to remove it completely.
Peel back the black adhesive strip that attaches the blue wire to the motherboard.
Repeat this step for the strip that attaches the black and red wires to the motherboard.
Using a soldering iron, desolder the blue, red, and black wires from the motherboard.
Follow these steps in the reverse order to reassemble your device.
7 участников успешно повторили данное руководство.
Комментариев: 3
Thank you, have you upgraded to a new 2019 Ultra model yet?
Soldering the fan to the mobo is a suck move. However, they used a good quality bearing-less fan.
Can you gve me areson? will it suck out the perfomance?
