Введение
In this guide, we'll show you how to replace the motherboard in your Roku XD 2050X.
Выберете то, что вам нужно
Turn the device upside down.
Remove the two rubber pads using a plastic spudger.
Insert spudger between upper and lower frame underneath the port access.
Guide spudger around to loosen upper and lower frame to pry frame apart.
Gently remove upper frame.
On the side of the board opposite the ports, find and tilt back the tab securing the board in place.
Lift the motherboard out of the lower frame.
Еще один человек закончил это руководство.
