Введение
In this guide, we will show you how to replace the circuit board inside your Roku XD remote control.
Выберете то, что вам нужно
Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
Gently twist the spudger to separate the top and bottom halves of the remote.
Using either end of the spudger, gently lift and remove the clear keypad backing.
Now that the remote is disassembled, you simply need to reassemble the remote using the replacement circuit board.
To reassemble the remote once you've replaced the circuit board, return to the remote control disassembly page and follow the steps in reverse order.
Еще один человек закончил это руководство.
