Введение
This guide shows you how to remove the rear panel, giving access to all the internal components.
Warning: this amplifier is heavy. Take care to lift it safely. You should get a second person should help you lift it on or off a speaker stand.
Выберете то, что вам нужно
Switch off and unplug the amplifier.
With the amplifier on the work bench, turn it around so that you have the rear panel facing you.
Remove two Phillips #2 screws from the bottom of the rear panel.
Remove 2 Phillips #3 screws from the left hand side.
Remove 2 Phillips #3 screws from the right hand side.
Remove 2 Phillips #3 screws from the top of the case between the carry handle and the top control panel.
It should now be possible to remove the rear panel away from the case, if necessary easing it away from the case by inserting a small flat screwdriver between the panel and the wooden case along the top and/or the bottom.
Lay the rear panel on the bench behind the case. You now have access to the electronics and the speakers.
To remove either jack board, first disconnect the multi-way connector by releasing the locking bar with a small flat screwdriver.
Remove the plastic nuts on the rear panel from all the jack sockets on the board you wish to remove.
Lift the jack board away from the rear panel.
3 участников успешно повторили данное руководство.
