Введение
To do this replacement you need to make sure you have the correct size allen wrench and the washer fits properly because each roller blade has different specifications. If you do not put the washer on correctly it could cause the wheels to not spin as freely as they should. This fix is neccesary because if the washer is warped the wheels wont spin well or at all causing the front wheel to lock up.
Выберете то, что вам нужно
Retrieve the new plastic washer and insert between the blades on the inner side. Do the same to the other side, so that both sides have new plastic washers
Replace the wheel without dislodging the new plastic washers and center the hole of the wheel in each plastic washer.
You just finished replacing the plastic washers, you can now go out and skate to your hearts content
Еще один человек закончил это руководство.
3 Комментариев
ভিঢা বাজার অগ্রণী ব্যাংকের
