Roller Skate Bearing Replacement
Выберете то, что вам нужно
  1. Roller Skate Bearing Replacement, Wheel Bearings: шаг 1, изображение 1 из 1
    • Remove the wheel
    • Grip the nut with the pliers and rotate counter-clockwise until loose.
    • Remove the nut and the wheel from the axle.
    • Try not to lose the washer (the small metal disc) between the center of the axle and the wheel.
  2. Roller Skate Bearing Replacement: шаг 2, изображение 1 из 2 Roller Skate Bearing Replacement: шаг 2, изображение 2 из 2
    • Remove the bearings
    • Place the wheel partially onto the axle so it is only touching the first bearing.
    • Twist the wheel downward to free the bearing from its socket.
    • Repeat this step for both bearings.
  3. Roller Skate Bearing Replacement: шаг 3, изображение 1 из 3 Roller Skate Bearing Replacement: шаг 3, изображение 2 из 3 Roller Skate Bearing Replacement: шаг 3, изображение 3 из 3
    • Place new bearings inside the wheel
    • Place the bearing onto the axle with the cover facing downward.
    • The bearing cover is the plastic or metal centerpiece that protects the steel balls from dirt and grime. It is normally a different color from the rest of the bearing (for an example, ours are red). Some bearings have covers on both sides, in which case it doesn't matter which side they are facing.
    • Place the wheel onto the axle and force it down onto the bearing. This will force the bearing into the socket.
    • Repeat these steps for both bearings.
    • Make sure both bearing covers are facing outward from the center of the wheel.
    • If you do not have new bearings, there is a bearing cleaning guide you can use to make your old ones good as new.
  4. Roller Skate Bearing Replacement: шаг 4, изображение 1 из 1
    • Place the wheel back onto the axle
    • To ensure that the wheel is facing the proper direction, make sure the decals on the wheel are facing outward.
  5. Roller Skate Bearing Replacement: шаг 5, изображение 1 из 1
    • Secure the wheel into place
    • Place the nut onto the axle.
    • Grip the nut with the pliers.
    • Rotate clockwise until tight. There should be a tiny bit of space between the nut and the wheel.
    • Try not to tighten the nut too much or else the wheel may not spin effectively.
    • If one of your wheels still doesn't spin as well as the rest, check to make sure the bearings are fully placed in their sockets.
  6. Roller Skate Bearing Replacement: шаг 6, изображение 1 из 1
    • Repeat steps 1-5 for each wheel
Заключение
Congratulations! You now have a new set of bearings. Give those wheels a proper spin.
Philippe
Участник с: 02/10/16
101 Репутация
1 руководство автора
Команда
Colorado Springs, Team 5-1, Mcmichael Spring 2016 Участник Colorado Springs, Team 5-1, Mcmichael Spring 2016
UCCS-MCMICHAEL-S16S5G1
3 членов
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 31
За последние 30 дней: 132
За всё время: 22,706
