Введение
These instructions will show you how to remove and replace the ball-bearings inside the wheels of four cornered "quad" roller skates. It is important to clean or replace the bearings regularly so the skates function properly.
Выберете то, что вам нужно
Remove the wheel
Grip the nut with the pliers and rotate counter-clockwise until loose.
Remove the nut and the wheel from the axle.
Remove the bearings
Place the wheel partially onto the axle so it is only touching the first bearing.
Twist the wheel downward to free the bearing from its socket.
Repeat this step for both bearings.
Place new bearings inside the wheel
Place the bearing onto the axle with the cover facing downward.
Place the wheel onto the axle and force it down onto the bearing. This will force the bearing into the socket.
Repeat these steps for both bearings.
Secure the wheel into place
Place the nut onto the axle.
Grip the nut with the pliers.
Rotate clockwise until tight. There should be a tiny bit of space between the nut and the wheel.
Congratulations! You now have a new set of bearings. Give those wheels a proper spin.
