Введение
This guide explains how to remove the plastic sensor cover in the Rosewill NEON M62 mouse. This should be done if the mouse is plugged into a computer, when the mouse is moved, the cursor does not respond.
Выберете то, что вам нужно
Place the mouse so the bottom is facing upwards.
Remove the plastic skates.
Remove the two 5 mm screws with a Phillips #00 screwdriver.
Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
