Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide is for the removal or installation of the rotary multi selector wheel.
Запчасти
Детали не указаны.
  1. Unscrew the two 3.5mm Phillips screws from the side with the AV outlet. Unscrew the 3.5mm Phillips screw from the opposite side of the camera. Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  2. Carefully remove the back casing from the camera.
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  3. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  4. Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up. Gently pull the ribbon from the logic board with tweezers.
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
  5. Lift up the metal cover and its button slowly using the tweezers. Lift up the metal cover and its button slowly using the tweezers. Lift up the metal cover and its button slowly using the tweezers.
    • Lift up the metal cover and its button slowly using the tweezers.
Заключение
Andrew Lau
Участник с: 18.04.2013
1 Репутация
1 руководство автора
Команда
Cal Poly, Team 8-56, Johann Spring 2013 Участник Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 членов
Автор 18 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 385
