Введение
Damaged power cord? Why throw your saw away when you can fix it. If your saw has a damaged power cord, this guide will provide you with step-by-step instructions for the power cord replacement.
Выберете то, что вам нужно
Orient the saw so that the handle is closest to you and the saw end points towards the left.
Push down on the grey lock on the right side of the handle to unlock it.
Pull the handle to detach it from the saw.
Lift the black lock at the tip of the saw to unlock the depth gauge.
Pull the depth gauge to detach it from the saw.
Rotate the device so that the bottom of the saw is facing upwards.
Remove the six 20mm screws with a 6mm flathead screwdriver.
Cut through the stickers on the right and left sides of the saw using a metal spudger.
Pull off the top half of the casing.
Remove the two 14 mm screws on the plastic plate holding the power cord with a flat head screwdriver.
Lift off the plastic plate holding the power cord with a tweezer.
Pinch the two white clips with your thumb while simultaneously removing the black and white wires.
Remove the power cord from the saw.
2 участников успешно повторили данное руководство.
