Введение
If the safety lock pin is stuck, you will need to replace it. In order to replace the safety lock pin, you have to remove the saw casing and motor assembly.
Выберете то, что вам нужно
Orient the saw so that the handle is closest to you and the saw end points towards the left.
Push down on the grey lock on the right side of the handle to unlock it.
Pull the handle to detach it from the saw.
Lift the black lock at the tip of the saw to unlock the depth gauge.
Pull the depth gauge to detach it from the saw.
Rotate the device so that the bottom of the saw is facing upwards.
Remove the six 20mm screws with a 6mm flathead screwdriver.
Cut through the stickers on the right and left sides of the saw using a metal spudger.
Pull off the top half of the casing.
Detach the wire connected to the bottom of the motor assembly.
Rotate the motor away from you so that the second wire is visible, and detach that wire as well.
Flip the saw so that the 'Rotozip' label is facing upwards.
Remove the safety lock pin and spring.
Один комментарий
Where can I find replacement parts for this Particular rotozip model #reb01 type 2
