Введение
If the metal soleplate on the Rowenta Focus DW5080 becomes corroded due to mineral build up, or it will not heat up, it needs to be replaced. This guide provides instructions for the soleplate, (metal plate that forms the base of the iron) replacement.
The user needs to make sure that the iron is off and not hot before replacing the soleplate or they could be burned.
Выберете то, что вам нужно
Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
Pry the back cover of the iron off using a metal spudger.
Remove the back cover, exposing the wiring in the iron.
Remove the frontmost (main) power cord to give access to inner wiring and accessories.
Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
Lift out the piece.
Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
Unhook the clips on the top of the metal piece.
Using the metal spudger, remove the metal piece on the tip of the iron.
Using the T20 screwdriver, remove the 20 mm screw that was under the metal piece on the tip of the iron.
Using the T20 screwdriver, remove the two 20 mm screws on either side of the back of the iron.
4 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
hi how do i clean sole plate inside ??????????????????? wath sort of sealent do they use to seal it or where do you get it from????????????????
