Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Vacuum does not power on even after the battery has been replaced? The motherboard may be defective. Follow this guide on how to change it for a new one!
Запчасти
Детали не указаны.
  1. Flip the vacuum over so that the wheels are facing you. Use a Phillips #1 screwdriver to remove the four 10mm screws that surround the battery cover.
    • Flip the vacuum over so that the wheels are facing you.
    • Use a Phillips #1 screwdriver to remove the four 10mm screws that surround the battery cover.
  2. Lift up the battery cover to reveal the battery.
    • Lift up the battery cover to reveal the battery.
    • Remove the battery.
  3. Remove the eight 10 mm Phillips #1 screws. Remove the eight 10 mm Phillips #1 screws. Remove the eight 10 mm Phillips #1 screws.
    • Remove the eight 10 mm Phillips #1 screws.
  4. Hold the front bumper and pull it off. It requires a lot of force to pull the bumper off. It requires a lot of force to pull the bumper off.
    • Hold the front bumper and pull it off.
    • It requires a lot of force to pull the bumper off.
  5. Pry off the back bumper by going around the entire top of the bumper with the metal spudger. Pry off the back bumper by going around the entire top of the bumper with the metal spudger. Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
    • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
  6. To access the motherboard entirely, lift the top portion of the vacuum off. To access the motherboard entirely, lift the top portion of the vacuum off. To access the motherboard entirely, lift the top portion of the vacuum off.
    • To access the motherboard entirely, lift the top portion of the vacuum off.
  7. Locate the four main 10mm screws on the underside of the motherboard.
    • Locate the four main 10mm screws on the underside of the motherboard.
  8. Use a Phillip's #1 screwdriver to unscrew and remove the four 10 mm screws. Use a Phillip's #1 screwdriver to unscrew and remove the four 10 mm screws.
    • Use a Phillip's #1 screwdriver to unscrew and remove the four 10 mm screws.
  9. Pinch the two tabs together, shown here, to loosen the motherboard out of the vacuum. Lightly pull on the silver box shown to lift the motherboard out. Lightly pull on the silver box shown to lift the motherboard out.
    • Pinch the two tabs together, shown here, to loosen the motherboard out of the vacuum.
    • Lightly pull on the silver box shown to lift the motherboard out.
Заключение
Jessica Alimonti
Участник с: 17.02.2017
114 Репутация
1 руководство автора
Команда
USFT-Lacy-S17S005G2 Участник USFT-Lacy-S17S005G2
Meetup
4 членов
Автор 5 руководств
Комментариев: 3
This was GREAT.... Lots of pics :-)
I was able to pull the mother board without much trouble. Mostly scared of breaking the connections.
NOW???? Where do I buy the darn thing?
Please respond,
Robert
Robert Kilgore - Ответить
Unfortunately, it looks like Moneual had some fraud issues and went under in 2014. It may be difficult to get your hands on replacement parts for the Rydis H68 Pro. =[
Richard Suovanen -
where are the internal batteries CR2032 ?? I have heard that problems maybe due to internal batteries and not motherboard. Unable to get top off.
Do you know how to do a factory reset ? thank you. N. Tribley Oct. 23
naomi - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 12
За всё время: 751
