Введение
This guide demonstrates how to replace the level gauge of the drill, located along the top of drill. The process requires opening the drill, but does not require removing any of the internal electronic components.
Запчасти
No parts specified.
  1. The battery can shock you.  Only touch plastic, non-conductive components. Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards. Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior. Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. PC Laptop Batteries
    An easy fix for a big power boost.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  4. Gently lift the casing from the drill body. Take the casing completely off the drill body to gain access to the interior of the drill.
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  5. Rotate the Drill 180 degrees so that the top is facing you. Lift the level gauge out from the top corner of the drill. The level gauge is Part #: 3000909
    • Rotate the Drill 180 degrees so that the top is facing you.
    • Lift the level gauge out from the top corner of the drill.
    • The level gauge is Part #: 3000909
Заключение
Joseph Eckstein
Участник с: 07.04.2015
1 500 Репутация
Автор 9 руководств
Команда
Cal Poly, Team 17-6, Forte Spring 2015 Member of Cal Poly, Team 17-6, Forte Spring 2015
CPSU-FORTE-S15S17G6
4 членов
Автор 9 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 190
