Введение
This guide covers the removal process of the outer case. The process does not require removing any of the internal electronics; however it is recommended that the battery is removed in order to reduce the risk of shock. The screws in the case are standard Torx T10 screws. It is advisable to have some place safe to keep all of the screws so that the case can be properly secured during reassembly.
Запчасти
No parts specified.
  1. The battery can shock you.  Only touch plastic, non-conductive components. Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards. Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. PC Laptop Batteries
    An easy fix for a big power boost.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  3. Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior. Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  4. Gently lift the casing from the drill body. Take the casing completely off the drill body to gain access to the interior of the drill.
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
Заключение
Joseph Eckstein
Участник с: 07.04.2015
1 500 Репутация
Автор 9 руководств
Команда
Cal Poly, Team 17-6, Forte Spring 2015 Member of Cal Poly, Team 17-6, Forte Spring 2015
CPSU-FORTE-S15S17G6
4 членов
Автор 9 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 3
За всё время: 257
