Введение
If your Ryobi P501G starts failing when using your saw, you may want to think about replacing the component. The failure may be a result of heavy use or a crack. The replacement of the blade is not complex. You will need the indicated screwdrivers and a spudger to complete this task. There are no warnings or potential hazards when replacing this part.
Выберете то, что вам нужно
Locate the area where the blade is connected to the motor, where the circular covering is on the Ryobi P501G.
Unscrew clockwise and remove the bearing in the middle, connecting the blade to the motor. This will also allow removal of the blade guard.
Remove the four black screws holding the black bearing and remove the bearing itself.
Once the black bearing is off, remove the transparent cover of the blade.
Once the cover is off, remove the blade.
