Введение
If the shell of your Ryobi P501G is damaged or compromised, you might want to think about replacing it. A damaged shell might be the result of wear and tear, or overuse. The opening up is not too complex and does not require a lot of experience. You will need the indicated screwdrivers to accomplish the task. There are no warnings or potential hazards when replacing this part.
Выберете то, что вам нужно
Locate the area where the blade is connected to the motor, where the circular covering is on the Ryobi P501G.
Unscrew clockwise and remove the bearing in the middle, connecting the blade to the motor. This will also allow removal of the blade guard.
Remove the four black screws holding the black bearing and remove the bearing itself.
Once the black bearing is off, remove the transparent cover of the blade.
Once the cover is off, remove the blade.
Remove the three screws on the inside base of the metal casing of the blade.
Pull the metal blade casing off of the Ryobi P501G body.
Remove all of the screws located on the right side of the saw.
Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
Pull back the shell to access the housed parts underneath.
