Выберете то, что вам нужно
Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
Insert needle nose pliers to remove the retaining pin at the top of the bearing.
Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
After following prerequisite guides to get to the presented step, remove motor assembly from back housing.
Motor Assembly
Motor Assembly Housing
Using pliers to grab onto the elongated aluminium exterior of the housing, begin to slowly wiggle the motor assembly housing until it comes loose.
After the wires have been detached it should be relatively easy to remove and replace the Motor Assembly Housing
