Выберете то, что вам нужно
Use a Torx T20 screwdriver to remove the nine 16.5 mm screws around the trigger assembly.
Use a Torx T20 bit or screwdriver to remove the six 19 mm screws securing the gear case cover.
Use a Phillips #2 bit or screwdriver to remove the four 37 mm screws from the top and the bottom of the gear case.
Почти готово!
Заключение
