Введение
This guide will show you how to replace the fuel lines and filter on your Ryobi RY253SS String Trimmer. It requires no prior experience in small engine repair.
The fuel filter, for this model string trimmer, needs to be replaced either after 25 hours of run time or each year. The filter ensures that debris does not enter the fuel system of the engine, thus maintaining proper performance of your string trimmer. Another reason you may need to replace the fuel filter is if you have not been using the proper fuel to oil ratio in the fuel mixture. This can cause the engine problems when starting. This fix can breathe new life into your string trimmer and have it running similar to the day you got it out of the box.
Выберете то, что вам нужно
With your hands, remove the air filter cover from your edge trimmer.
Remove the air filter before moving to the next step.
Remove the two M5 x 45 mm shoulder screws attaching the air filter housing to the engine frame using a flathead screwdriver.
Pull the housing away from the engine block.
Pull the carburetor away from the engine block.
Gently remove the input fuel line from the carburetor.
Gently remove the output fuel line from the carburetor.
Use the cutting pliers to cut the excess line flush to the tank.
Use a screwdriver to push the remaining line into the tank.
Thread the gripping tool through the input line on the tank.
Thread the tool through the gas cap opening.
Place your finger through the key ring end of the gripping tool.
Pull the tool until the line begins to make its way through the hole.
Grab the fuel line directly with your hand to continue pulling it completely through.
Using the same methods as the previous steps, thread the output fuel line through the tank.
Attach the output fuel line back to the carburetor.
Attach the input fuel line back to the carburetor.
To reassemble your device, follow steps 1 and 2 in reverse order.
3 участников успешно повторили данное руководство.
