Введение
This guide will help you replace the back cover of you controller. You’ll only need a Phillips #000 screwdriver to complete this guide.
Запчасти
Никакие детали не требуются.
  1. Remove the screws on the back of the controller with the Phillips #000 screwdriver. Hold the controller with the bottom plate facing up, gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside. Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
    • Remove the screws on the back of the controller with the Phillips #000 screwdriver.
    • Hold the controller with the bottom plate facing up, gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
    • Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
    • Place screws on magnetic project mat to avoid losing any screws.
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
Заключение
2 участников успешно повторили данное руководство.
Omar Shorab
Участник с: 23.04.2018
249 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S24-G12, Maness Spring 2018 Member of Cal Poly, Team S24-G12, Maness Spring 2018
CPSU-MANESS-S18S24G12
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 2
За 7 дней: 3
За 30 дней: 9
За всё время: 105
