Введение
How to open a SPÖKA light, how to replace the battery pack, how to put it all back together.
Выберете то, что вам нужно
The most tricky part is to get the inner body out of the rubber shell.
I was supprised. The rubber can actually take some stretching
you end up with an egg shaped plastic body
Now we need to remove the bottom cap.
carefully bend the two hoocks inwards (e.g. with a small screwdriver) ad remove it
Now you can split the the body into two
you now can extract the battery pack.
on top you see the little switch to turn it on and off.
the LED are strapped with a cable tie around the battery
at the bottom lies the connector for recharging
remove the cable tie
remove the warapping of the battery pack
desolder the two cables from the pack
now it should look like the pack on the right
glue the new batteries together. - keep in mind, to alter the ends.
at the end you should have a new pack with (+) (-) (+) at one end and (-) (+) (-) at the other
this is the tricy part.
the new pack should be facing you with (+) (-) (+)
solder the right (+) to the (-) in the middle
Lolder the upper left (-) to the (+) in the middle
I used some old wire for it
Now solder the short black wire to the upper (-). It must be the only (-) with no connection yet
Solder the red long wire to the lower left (+). Also this must be the only (+) left without any connection
let it cool off
Use the cable tie to strap the LED back to the battery pack
isolate the open ends of the batterypack. It must not be able to create a short circuit. I used the hot glue. but also some thick rubber tape can do the job
put it back together in the shell
be aware to place the switch and the connector for recharging on the right places
Now its getting ugly again.
you have to put the shell back into the rubber
this could take a while
Be aware to put the connector on the right side, so you are able to recharge it again
Switch it back on and enjoy the bright light
Please remember that you altered a electric device.
never let your new spöka charge unattended and keep a good eye on it for short circuits
be aware that you altered an electric device!!!
If you do not know what you are doing... dont to it
2 участников успешно повторили данное руководство.
Один комментарий
This is a good writeup. One flaw is the old battery photo doesn’t show the markings — not everyone will want to hot-glue a NiMH battery pack from scratch, when you can purchase 4 for $10 on Amazon (from a baby monitor or cordless phone). These they have the advantage of using JST connectors (though you’d need to solder on a socket to take advantage of that).
ALSO - if you have the “fat Spoka” as I do, it uses 3 NiMH formed in a triangle (byd nimh battery h-aaa550X3) and those are IMPOSSIBLE to find so no retail option there — I probably will have to hot-glue the battery pack… :-)
