Введение
If your Spot X SPOTXB's antenna is damaged, it will affect the device's functionality by losing signal connection. It's essential to replace the faulty antenna as the entire device relies on it, and for that, you might require opening up the device. The steps are relatively easy, but you need to be cautious while opening the device, and you should remember to unplug the device from any external power sources to avoid electrical hazards.
Выберете то, что вам нужно
Turn off the device completely by holding the power button for 10-20 seconds to force a shutdown.
Remove the seven 4.1 mm screws from the back of the device using a T4 Torx screwdriver.
Gently unplug the antenna connector from the device's internal board.
Remove the antenna from the device.
2 человек успешно провели ремонт по этому руководству.
