Введение
If SPOT X SPOTXB's USB-port is broken, this will affect the device's charging ability and any data transfer activities. So, it is important that the USB-port for this device is able to work anytime, any day. To replace the broken USB Port, it might require de-assembling the device.
Выберете то, что вам нужно
Turn off the device completely by holding the power button for 10-20 seconds to force a shutdown.
Remove the seven 4.1 mm screws from the back of the device using a T4 Torx screwdriver.
Remove the ten 2.9 mm screws from the motherboard using a T5 Torx screwdriver.
Еще один человек закончил это руководство.
