Введение
Follow this guide to remove a dead battery and replace it with a new one.
Запчасти
Никакие детали не требуются.
  1. Gently place the instrument upside-down on a soft surface.
    • Gently place the instrument upside-down on a soft surface.
    • Locate the battery cavity cap and screws.
  2. Use a phillips head screwdriver to unscrew both screws. Two #1 1mm long screws.
    • Use a phillips head screwdriver to unscrew both screws. Two #1 1mm long screws.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Remove the cap by lifting upwards to reveal the battery. Remove the cap by lifting upwards to reveal the battery.
    • Remove the cap by lifting upwards to reveal the battery.
  5. Gently lift the battery from the cavity. Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery. Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
    • Gently lift the battery from the cavity.
    • Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
Заключение
To reassemble your device, follow these instructions in reverse order with a fresh battery.
Chris Pittner
Участник с: 11.01.2013
163 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 5-18, Forte Winter 2013 Member of Cal Poly, Team 5-18, Forte Winter 2013
CPSU-FORTE-W13S5G18
4 членов
Автор 8 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 1
За 7 дней: 1
За 30 дней: 5
За всё время: 905
