Введение
Piston O-rings for older Saeco Brewgroup.
This is the version with the Glasball.
Выберете то, что вам нужно
I show you the O-rings in the top piston of the brewgroup. I don't write much, because my english is bad, but the photos speak for themselves. Good luck
Two screws, PZ 1
Careful, there is a spring.
Remove the piston. More information in my guide " Disassembling & Cleaning the Brewgroup" here.
Screw PZ 1
Counterrotate turning the screw.
Then pull that thing and you find another seal
...and then I found a crack in my piston. That can not be repaired. So I had to buy a new piston.
4 участников успешно повторили данное руководство.
