Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Piston O-rings for older Saeco Brewgroup.
This is the version with the Glasball.
Инструменты
Запчасти
Детали не указаны.
  1. I show you the O-rings in the top piston of the brewgroup. I don't write much, because my english is bad, but the photos speak for themselves. Good luck Two screws, PZ 1 Careful, there is a spring.
    • I show you the O-rings in the top piston of the brewgroup. I don't write much, because my english is bad, but the photos speak for themselves. Good luck
    • Two screws, PZ 1
    • Careful, there is a spring.
  2. Spring, O-ring and a GLASBALL. Spring, O-ring and a GLASBALL. Spring, O-ring and a GLASBALL.
    • Spring, O-ring and a GLASBALL.
  3. Ja
    • Ja
  4. Remove the piston.  More information in my guide " Disassembling & Cleaning  the Brewgroup" here. Remove the piston.  More information in my guide " Disassembling & Cleaning  the Brewgroup" here. Remove the piston.  More information in my guide " Disassembling & Cleaning  the Brewgroup" here.
    • Remove the piston. More information in my guide " Disassembling & Cleaning the Brewgroup" here.
  5. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Screw PZ 1 Counterrotate turning the screw. Then pull that thing and you find another seal
    • Screw PZ 1
    • Counterrotate turning the screw.
    • Then pull that thing and you find another seal
  7. Details Details Details
    • Details
  8. Tools for cleaning, ja toothbrush Tools for cleaning, ja toothbrush Tools for cleaning, ja toothbrush
    • Tools for cleaning, ja toothbrush
  9. There are two types of O-rings. For this type of piston  you need the smaller. There are two types of O-rings. For this type of piston  you need the smaller.
    • There are two types of O-rings. For this type of piston you need the smaller.
  10. Grease it a liitle. Just put it back, no problem. Just put it back, no problem.
    • Grease it a liitle.
    • Just put it back, no problem.
  11. ...and then I found a crack in my piston. That can not be repaired. So I had to buy a new piston.
    • ...and then I found a crack in my piston. That can not be repaired. So I had to buy a new piston.
Заключение
4 участников успешно повторили данное руководство.
Schwarzstein
Участник с: 15.07.2013
2 418 Репутация
Автор 14 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 25
За всё время: 1,846
