Saeco Intelia HD8752 LCD Display Panel Replacement
Выберете то, что вам нужно
  1. Saeco Intelia HD8752 LCD Display Panel Replacement, Disconnecting power: шаг 1, изображение 1 из 1
    • First, start by putting appliance into standby mode. Then put general switch to 0. Finally, disconnect power cord.
  2. Saeco Intelia HD8752 LCD Display Panel Replacement, Removing the bean coffee container and the upper casing cover: шаг 2, изображение 1 из 3 Saeco Intelia HD8752 LCD Display Panel Replacement, Removing the bean coffee container and the upper casing cover: шаг 2, изображение 2 из 3 Saeco Intelia HD8752 LCD Display Panel Replacement, Removing the bean coffee container and the upper casing cover: шаг 2, изображение 3 из 3
    • Start by removing all coffee beens from the container.
    • Remove the screw in the middle of the bean container protection and remove the bean container protection.
    • Remove the three screws of the been container and remove the been container.
    • Use a magnet to get them up so that you don't drop them into the grinder hole.
    • You can now remove the upper casing cover by pulling it up gently (picture 2).
  3. Saeco Intelia HD8752 LCD Display Panel Replacement, Removing left side casing: шаг 3, изображение 1 из 3 Saeco Intelia HD8752 LCD Display Panel Replacement, Removing left side casing: шаг 3, изображение 2 из 3 Saeco Intelia HD8752 LCD Display Panel Replacement, Removing left side casing: шаг 3, изображение 3 из 3
    • Remove the two screws on the top of the left panel.
    • Remove the drip tray.
    • Remove the water tank.
    • Below the water tank location, remove the bottom screw of the left side casing.
    • Remove the left side casing by pulling it gently. Take care of the nick, at the middle of the panel (above the yellow marked screw).
  4. Saeco Intelia HD8752 LCD Display Panel Replacement, Removing silver front panel: шаг 4, изображение 1 из 3 Saeco Intelia HD8752 LCD Display Panel Replacement, Removing silver front panel: шаг 4, изображение 2 из 3 Saeco Intelia HD8752 LCD Display Panel Replacement, Removing silver front panel: шаг 4, изображение 3 из 3
    • If Pannarello is present, remove it first from hot water dispenser by pulling it firmly to the bottom. Next, open up service gate on the right of the appliance.
    • Remove the two right screws of the silver front panel.
    • To remove the next screws, you must have removed left side casing as explained in previous step. Owners of Intelia machine with external milk carafe (HD8753/87)? Please, also have a look at Paul Tast comment below.
    • Remove the two left screws of the silver front panel.
    • Separate the silver front panel from the main unit by pulling it gently.
    • Be careful, you can't remove silver front panel without removing first the hot water dispenser !
    • Loosen or remove the two screws of the hot water dispenser.
    • Remove the silver front panel. Take care of hot water dispenser and left and right nicks of the panel.
  5. Saeco Intelia HD8752 LCD Display Panel Replacement, Removing the touch panel frame: шаг 5, изображение 1 из 1
    • Remove the three screws of the touch panel frame.
  6. Saeco Intelia HD8752 LCD Display Panel Replacement, Removing the LCD frame: шаг 6, изображение 1 из 1
    • Remove the LCD black plastic frame. It is simply placed into two necks.
  7. Saeco Intelia HD8752 LCD Display Panel Replacement, Removing LCD screen: шаг 7, изображение 1 из 3 Saeco Intelia HD8752 LCD Display Panel Replacement, Removing LCD screen: шаг 7, изображение 2 из 3 Saeco Intelia HD8752 LCD Display Panel Replacement, Removing LCD screen: шаг 7, изображение 3 из 3
    • Remove the two screws on each side of the LCD screen.
    • Disconnect the first connector.
    • Disconnect the other cable.
    • To disconnect the second cable, you need to lifts the flap of the connector.
  8. Saeco Intelia HD8752 LCD Display Panel Replacement, Install the new LCD screen: шаг 8, изображение 1 из 3 Saeco Intelia HD8752 LCD Display Panel Replacement, Install the new LCD screen: шаг 8, изображение 2 из 3 Saeco Intelia HD8752 LCD Display Panel Replacement, Install the new LCD screen: шаг 8, изображение 3 из 3
    • Disassemble the old LCD screen from support frame.
    • Clip the new LCD screen to the LCD support frame.
    • Reconnect the two cables.
    • Reconnect power cable and switch on the appliance. Colors (yellow, green) from the screen should be back :)
    • If it doesn't work, check connection after turning off the power.
    • To reassemble the appliance, follow this guide in reverse order.
Заключение
To reassemble your appliance, follow the instructions in reverse order.
18 участников успешно повторили данное руководство.
Jean T
Участник с: 02/19/16
621 Репутация
1 руководство автора
37 Комментариев
You're welcome :)
Jean T -
Jean, can you please look at my inline comments and include them in your main instructions? They are hidden to the user and they wont see these precautions until it too late. Again, thank you for this excellent super helpful guide with great pictures. I took a few of my repair Id be happy to send to you. I would have posted them but this site doesn't allow commentators to post pictures.
Paul Tast - Ответить
Hi Paul,
Thanks for your comments :) I have included some of them into the guide.
Jean T -
Very good Description! Trank you!!!
Rainer Bokowski - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 22
За последние 30 дней: 118
За всё время: 27,277
